Technical Looking at changing 2.0 20v cambelt in situ
North East
Been having a root about today, and I don't think this is going to be impossible.
The front driver's side engine mount will have to come off, and it's limited as to how far you can move the engine in situ as the driveshaft will catch the suspension on the way down.
Room is definitely tight, and it's gonna be fiddly, but I think I can do it.
Anyone managed it before and want to share a few tips?
Anyone know what the bolts are holding the crank pulley and various other bits in the engine bay, they ain't torx but a torx bit will do at a pinch.
Need to go get a new alternator and power steering belt now, may as well do them while they're off.
If I manage the job, I'll post a photo how-to. If not, you're all invited to the funeral :D
Confidence level thus far: High.
Well, done it. Started 9.30, finished 2.30 - in time for a shower and to go collect the bairn from school.
I have a few square inches of skin missing, but I always look like this after working on a car. It is fiddly, I had to modify a torx bit to get in, but otherwise it's not really that bad a job. Don't know why Fiat take the engine out, they're just taking the mick.
Will post a photo jobby of how it goes when I get some time.
Total cost:
£28 cam belt
£11 alternator belt
£11 power steering belt (old one was really buggered!)
I Said this quite a while ago. No Need to take engine out. Can be done in 2 hours with practice :) Fiat will always charge this price due to being book time.But I would of defintley changed the tensioner as this what fails most times :eek:
tensioners and pump!!!
never seen a 20v belt go, always the tensioner. Although thats just my experience!!!
the cause of pump and tensioner bearing failure is usually down to the belt being fitted too tightly in the first place, hence the reason we see premature failures.
in reality if everything is lined up and tensioned correctly the only wear that should occur is to the belt teeth.
prevention is much better than cure, hence the reason for 36k belt changes along with all the other potential failure items
this is a general recommendation - when using technical experience one can adopt a much more cost effective approach to maintenance, as Pete has demonstrated!
those of you that disagree can go on lining the pockets of the dealerships!
for those of you that like the sound of this, heres another tip from the trade
goes something like
remove covers
turn engine over to align the timing marks
take stanley knife and cut long the middle of the belt all around
remove out half of belt
fit new belt half way on
remove remains of old belt
push new belt fully home and chek tension
rotate the engine using a socket on the flywheel bolt 2 complete turns
check the tension and timing marks
refit covers
drive away!
well from experience of the coupe 20vt, leakey water pumps, squeeling tensioners and failing tensioner bearings is a concern.
Im not nocking anyone, sod fiat and there charges, just in my opinion while your there may as well do the whole lot!!!
Well done for doing it yourself.
People just have different experiences!!
I hear what you're saying, and if I had the presence of mind to plan the job properly I'd have ordered the bits from Fiat a week ago, just I'm soooo disorganised! No offence taken.
I know now though that if I hear any funny noises or see any water leaks it's not gonna be an arse-falling-out situation, can all be sorted in a day easy :)
well done pete, I have to say, at those prices and knowing how much you love getting down and dirty with an internal combustion engine. Even if you needed to replace bits next year, its still worth the time and effort you've invested. And knowing you, it aint going to be a shoddy job, so you should have many miles of pleaseurable motoring.
Like the New Photo How To. Just the way i would do it. Its a little bit more tricky, to change the tensioner though, and if its got air-con also a bit more tricky. Just Make sure when you drop the engine the top radiator hose does not pull to hard on the rad or it will break the rad.. :D
