look lead question!!!!!- alpine amp
Power would obviously be thicker than the speaker cable.
Cabe used for power should be rated higher than the amp can draw so that no fires happen.
Liam
dont even attempt it, i am a bodger and i know what can happen if you cut corners :eek:
buy an amp wiring kit, and run a fused power cable to amp and make sure you earth it in a suitable place
as for speaker wires, dont use the thin bell wire, why have a decent amp and speakers being let down by the wires
how much wire are you after, i must have a mile of all kinds of fused power cables, earthing, flat speaker, Y splitters, rca leads, distribution blocks, etc... from when i stripped it all out my sei :eek:
it be no good to be now, cause im going to be starting from scratch if and when i put something into the punto, so get your tape measure out, tell me what length you need and i see what i can do :D
I have about 5 miles of unused bell wire. All its usefull for is remote wires that dont break and wiring things like lights....Richer sounds is very cheap for speaker cabling. But if Gaz is anything like me he will have miles of it spare. I'll have to take a photo of my room at the moment while im redoing my install. :p
