>MisaR, make up your mind on what the symptoms were.
-Symptoms were as I wrote in my first post (July 23 2005, 10:44 AM).
>First you say it was a hole in a pipe that was letting the pressure out too fast (although you said it was hard to start after several hours by when the pressure would have gone anyway)
-As I wrote earlier (July 24 2005, 7:39 AM), I didn't tray to start engine after 15 minutes or so.
>Now you say that the pump was not restarting after presurising the system.
-When car working in order and when you turn the key in the first position (engine not started), you can hear pump are working for a while and stop. Fredo wrote "The system "should" be under pressure when the noise stop." and I agree with that and add "With hole in the system, pressure wouldn't remain but pump didn't start agene self-alone." which means that without starting engine, just turn the key to the first position, pump stops after a while and wouldn't start agene without turning the key further (starting engine) or switching it completely off and turning it on agene.
>Sounds more like the fuel pump was at fault...
-After changing pipe with hole, two months ago, car is running well.
Misa.
