A
Alan
I have a set of locking valve caps but no fitting instructions. They are a silver coloured outer with a brass/copper threaded insert inside which is lose to move up and down but does not come out. There is a threaded hole in the side of the silver, outer casing and a one off small tool which screws into the hole. Does anyone have a set of these and know how they are fitted? Are you supposed to use the tool to squash the insert against the valve? If so how do i remove them when i want to pump the tyre up?
Any ideas appreciated!
