Technical  Lights on dashboard
superfestiva
Hi:
Anyone has a list of all lights on the dashboard of the Marea?
Don't know what all of them mean...:confused:
Roberto said:
They are all listed in the owners manual if you have it :)
I don't have it...I bought the car without it...I've tried searching for it in the net and no luck yet...
polecat said:
If you can put up a description of those that you don't know I'll tell you what they mean.
Well:rolleyes: , the ones I can remember because me wife is working right now are:
1- One that looks like an injector? Does it turn on when you have clogged or bad injectors?
2- When you have the car in reverse gear I see two lights on and some chime sounds on the dashboard?..Regarding the lights there is one that says stop and one that has like a bulb lid on? Do the sounds come on only when you brake the car?
The Injector is a fuel/air/ignition system warning. It usually comes on for a few seconds when starting and can come on now and then when driving. It is only a problem if it stays lit all the time. A fuel additive is usually the first fix if it stays on together with a visual inspection of cables and sensors.
Bulbs on the dash usually mean you have lamps out. The side that says STOP will be the side with the blown bulb. A yellow lit bulb by itself is a sidelight and/or number plate lamp. It will also come on with STOP to indicate a stop light problem. If this only happens when you select reverse I would check your reversing lights.
Hope this helps.
i have a light on my dashboard come on today, any chance you could tell me what it means, its red, and theres a man on a chair with a circle on him. i have a y-reg fiat punto
Sounds like the airbag warning, sitting sideways with a beach ball on his lap.
If it is latched in then you need to get it checked at a dealer as it has to be reset by an ECU reader. There is not normally anything wrong with the airbag but get the wiring checked out, especially the passenger side harness, as it is a bit annoying having to get it reset by a dealer all the time.
Re: Lights on dashboard (Yellow his Time)
I'm hoping someone here can help,
I've one I can't find in the manual!
Above teh Battery and Oil Pressure Red lights is
a yellow one, I'm guessing it's Gearbox oil but it
doesn't seem to be in the manual anywhere!
Looks like a little yellow engine..
Any help appreciated!
Regards
DaveA
