Technical Light cluster issue!!
Hi :)
On my punto DRL is worth swapping left to right..
Burnt contacts are not unheard of.. my 1st bulb lasted 42k miles of constant use.. holder had certainly suffered with heat
@65k the other DRL went out
It looked ok.. so fiddled with it.. still going now 4k later
Good idea! I'll give that a try cheers
I already tried a new connector in which the ground fried like the first. I didn't feel any moisture in the wheel well where the main ground is so replacing the entire harness doesn't seem to be a likely solution. I'm going to replace the light bulb cluster because its ground pin looks destroyed and useless. Seems odd so many 500x's are having the same problem. I'm worried a new light cluster won't solve it either.
