Technical  Light 3rd gear?
Jaaya
Milan
Hi. I have a Fiat Grande Punto of the year 2009. About three months ago when coming back from work i mistakenly changed from 2nd to 3rd without pressing the clutch fully, so the gear grinded.. now I feel that the engagement of third gear has become lighter, as if its engagement doesn't require as much resistance as before. Does this indicate a problem with the syncs? Am I just overthinking? Would an actual problem with syncs or the rest of the transmission caused grinding instead of a " lighter engagement"?
Spend the energy saved by checking fluid levels( engine oil, coolant , brake fluid, screen wash, your coffee level) tyre pressures and condition.
Yes you are over thinking . Don't worry put the whole thing out of your mind.
Best wishes
J
Ok thanks. I thought it could have been because of a big transmission problem.
