doogal
To continue my master class in very slow Fiat mechanics, tonight I undid the LH driveshaft - 6 bolts 6mm Allen key. As I undid them oil/thin-grease started to seep out of the joint between CV joint and gearbox flange. I've now moved the driveshaft out of the way and tied it up but in order to do this, I had to compress the CV boot which forced grease out of a little hole in the gearbox end of the CV joint (does that make sense??)
This is the end of the CV joint on the driveshaft with hole from whence the grease came circled in red (sorry - poor photo editing with MSPaint):
This is the gearbox output shaft flange covered in grease from the CV joint:
Do I now need to rebuild the CV joint/boot? Or can I just take the boot off and fill with grease? Is there supposed to be a seal to stop grease coming out of the little hole? Or should the be a gasket between CV joint and g/box output flange? This would appear to be the source of the original leak, anyway.
All advice appreciated as always.
Doog.
Doog.
