Technical Gearbox Overhaul manual
Stockholm
Guys, I've got the service manual and think I'll manage to remove the gearbox. However I need the gearbox service manual to replace my bad synchronizers. There's a reference to this manual in the main service manual:
Document number 505.023/03 called "Overhauling gearboxes"
My guess it's a general manual describing several gearboxes and that section 03 is relevant for the Barchetta model.
Any ideas where I can find this?
Hi !
As this could be a futur inspection for me, i searched for this document, but didn't found it. But i found something interesting, located Here :
fiat-bg.com/Downloads/Software/FIAT%20Stilo%20eLearn.nrg
This is a copy of the fiat E-learn for the fiat stilo, including the 1.8 16v version. This is the same engine/gearbox as the barchetta one. In the Procedure area, you got everything about the gearbox and synchronizers disassembly, check, and re-assembly with the torque values.
In order to install the software, download the link above (521mo), and also download Daemon tools lite (google it, it's free). Daemon will allow you to read the NRG file as a cd inserted in you computer. Just open Daemon tools, click on add an image, and select the Fiat Stilo elearn.NRG file. Then the setup will launch. Hope this helps.
Cheers from France ;)
Already got the service manual, you only have the disassembly of the gearbox from the engine, you don't have the full gearbox disassembly. May be it can depend the version of the manual you got ;)
A very good version is available here : download.fiat-bg.org/Books/Barchetta/
