General Leaking Problem!!!
Floans
Italy
I have a fiat brvai 2011 1.6 multijet diesel.
I have problems leatly with water leaking.
Can someone explain where is the problem here on video
  • VID_20250429_212741.mp4
    75.8 MB
It appears to be in the region of EGR valve but also the water cooling on the oil filter assembly(which I have had trouble with in the past on a 2010 1.6 Fiat DobloMJ), though in my case it put oil into the radiator coolant.
The trouble is in your case it has been leaking for a while judging by the antifreeze stains.
If it was me I would clean it off as much as possible, then with engine off use a pressure tester to equal the normal coolant running pressure and inspect for leaks.
Note don't exceed recommended pressure or you may make more leaks.:(
On the water hoses they have plastic (quick fit ends) with rubber O rings inside, any of those could be causing the problem.
On the bottom right is the oil cooler, but there are many other sources.
This is a photo of the back of engine to give an idea of the problem locating the leak.;)
