Laptop Respray?
Laptop Respray?
soap_dodger
Not gay, ecstatic!
Morecambe
I want to respray my laptop to a glossy black colour, Has anyone ever done this???
I know what I need to do, I just want to see how long I will be without a laptop and how long it will take.
Anyone know of any links to sites to help me???
Thanks,
Jamie :D
I did that with my HP DV4000, i painted it with that light bluey/silvery mk2 punto colour.,., it came out great, like a new laptop., ill post a pic later..,.,
serin, its easy than you think, iv taken apart my dell one and another one, i was rather worried taking apart something worth £100's and not knowing what i was doing, but it turned out to be **** easy (y) i fitted a new case, so the whole lot had to come apart.
if your just spraying you shouldnt have to take it apart completly, just half kinda.
and i sprayed mine too, didnt take it apart tho, just sprayed it... not a good idea :p
Here some pics of mine, there not great photos, you cant really see the metalic in the paint.., the other laptop is the same colour the blue one used to be.,.,
Vtec, did you use spray paint to respray it??? Did you use car spray paint???
I got some plastic spray paint to do it and I tested it on an old PC speaker I had lying around. But I was able to scratch it off with my fingernail.
Thanks,
Jamie
Thanks,
Jamie
Primer?
Yes the preperation is the key(y) ., i used cellulose base paints, and pro equipment, but the same can be done with aerosols.,., we were painting a punto that colour so i killed 2 birds with one stone.,.,:D
Go to somewhere like halfords and pick whatever colour you like, dont forget to ask for plastic primer and laquer aswell and one of them multi-packs of sandpaper(There only a couple of pound).,.
Give the area to be painted a nice rub down with p1200 paper, this gives the primer grip. then put on a coat of plastic primer, you dont need much of this just make sure you dont miss anywhere.,.,
When thats dry start spraying the paint on but dont be tempted to get it all done i one go or it'll drip(n) , give it about 10 mins between coats.,.
When the paint is done start on the laquer, this can be put on slightly thicker than paint but just be carefull not to overdo it.,
Id give about 2-3 coats of laquer.,
The thicker the laquer, the more glassey it will look but too much in one layer can look foggy.,.,
when the laquer is dry, rub the piece down with p2000 paper (used wet and soapy, dont worry it wont ruin the paint).,., when thats done the laquer will be nice and smooth, now just rub it with compound like t-cut or something.,., the more you polish it the better it'll look.,.:D (y)
Job Done!..,
It sound pretty daunting now that im reading over this but it not too bad(y) .,., you'll do great!(y) :D
