General Lamber sensor
bellini
Hi people merry Christmas to you all. Was gonna change my exhuast today just wondered if I needed to put the lamber sensor back on or will it run ok without? Cheers
Hi, :)
no idea what motor you've got, but generally without a signal pack from the probe you'll get a MIL , and engine MAY go into "limp mode", :eek:
change it;)
The engine will run, but in a very rich mixture mode and thus not economical.
If the old one still works, just put in back and if not replace it. If you buy a new one, have a close look on the wiring, some need to be (re)wired, some are plug and play.
I got my self a new lamba sensor and just my luck it needs re-wiring. Can any one help?
The original lamba sensor has a single plug with 4 wires.
New lamba sensor has 2 plugs, 2 wires in each plug. Any help would be much appreciated
take it back or splicing wires will be required, i had same problem on my mk1 55, you could get 2 plug connectors from scrap yard, stick that in new lambda, cut old lambda connector and stick in car connector and then wire it together
or cut both lambda connectors off, and wire it
