moonxx
This may help me or not but will ask the question for all you experts.
1. Does the lambda sensor sense heat or fuel mixture ?
2. Is the lambda sensor just a sniffer nose and detects how rich the mixture is ? and sends different ohms reading depending on mixture
3. If a lambda sensor is goosed will it:
a. can it make the spark plugs black because the ECU doesn't have a reading and doesn't know how to adjust mixture.
b. When the car reaches a warm condition make it stall at idle speed.
c. Also when warm will this make not start and why.
If their is any question that you are guessing please don't answer as this doesn't help just say "not sure
". I ask these questions because of my last post and have only 2 more sensors to replace this one and the TDC sensor. although an intermediate fuel pump problem will break my heart.:bang:
Last point to all you guys thank you very much for your help on earlier post,"seicento starting problem when warm" I will post thread if I eventially fix this seicento 899cc s.:worship:
