I've invested in a EOBD II code reader and the software for a laptop to read and graph sensors and codes in real time. I've only done limited testing (some of the places I drive to I don't fancy being seen with a laptop sitting on the passenger's seat!), but I've looked at a few things.
The coolant and air intake temperatures seem to be doing what I imagine is the right thing. First thing this morning before the car was started, they both read 5 degrees centigrade. After 15 minutes, the coolant temperature was at 80 degrees (started climbing quite rapidly from the moment the engine started) and the air intake rose to 21 degrees, which I imagine is due to the engine bay warming up. (The other night when I first tested it, I'd just got home after a longish drive - the air intake temperature said 47 degrees - would this be OK? I'd imagine it is really hot under the bonnet).
What I can't work out is if I've got a big problem with the lambda sensors, and/or (hopefully not) the converter. I've only had the opportunity to use the program a couple of times, and will need to do a lot more to establish any pattern, but I've copied a couple of captures of the graphs here.
Generally, as can be seen in both pictures, the top pre-cat sensor is doing what, from what I've read, is the right thing. It's voltage is quickly going high to low and back. However, the post-cat sensor is doing whatever it wants! The guide with the software says that the downstream sensor should generally stay level. Another place on the internet says the post cat sensor takes the reading to see how the pre cat sensor is doing, and it looks to me like the top one is working OK. I'm really confused!
One thing that I noticed is visible in this next picture. The area outlined with the black rectangle is when I pulled up outside my house, and the engine was idling, with a steady output from the post sensor of about .25 volts. A quick blip of the gas (Circled 1) and then the output goes back to .25v. Another quick blip (circle 2), and after the revs settled again, the output steadied at 0.8 volts. What's going on here?
I haven't had a good ride yet (which the car is capable of when it wants) to look at the sensor output then, and I'm also yet to do the same with the top cat sensor unplugged, which if anyone reads through the thread will recall me saying helped the car generally run much more consistently.
Could anyone (Decks, NumanR ?) tell me what I'm looking at, if anything. It couldn't be the converter, could it? The car has always done this, but yet whenever it wants it can ride beautifully. If the cat was broken, would that allow this? The car has only had one MOT and the emissions were spot on, but the car was riding spot on that day!
Any help much appreciated.
Thanks,
Del
