I was wondering guys, has lowering the suspension (ride height) changed fuel consumption at all as the car is lower so I guess better aerodynamics?
Murano16v That's a good idea about measuring the standard rear shocks bushes. It would even help to measure the shock bushes on a Fiat 500. I threw mine away when I got the FSD's, The Twins do you still have your old ones?
Here's why I didn't bother keeping my old shocks View attachment 127858
Yes but I don't have a vernier guage : /
If the bolt was moving in the metal eye (hole/sleeve through the bush) it would surely wear the facing surfaces of the bush eye/sleeve rendering the bolt loose. If this was the problem it would mean constantly tightening the bolt as it would wear the faces of the bush over and over. The bolt on my shock remains very tight. This us why I'm not convinced it's the bolts.
More likley it's hydraulic knock. This occurs if there us the slightest void not filled by the damping fluid. The same thing happens in mountain bike forks and also have had this happen in the rear shock if mtb. Fox (who also make shocks for motocross bikes and also special off road vehicles confirmed that this type if knock is typical in 1. Shock with 'platform' damping (like the FSD's) and when oil chamber has any sort of void/under filled. Also only one of my rear shocks rattles btw.
It would be handy if someone has a standard Abarth rear shock lying around and could measure the inside diameter of the bush. If it's exactly 12mm as are the Koni's then this theory about the cause of the knocking is flawed.
I meant of course shank diameter... Sorry!Original upper shocks bolts have 9 mm shaft diameter, lower shocks bolts have 11 mm shaft diameter.
My car has had its rear shocks replaced under warranty today....but I had my dashcam in the car and it stays on for 15 mins after the ignition is turned off.
I could see the roadtest and listen to the mechanic saying that it's probably my winter tyres or the child seat in the back and not the shocks. I will edit it down and upload it later.
Interesting I had our 500 rear Konis replaced the other Month with the new model/part number rear shock and they are so much better. It takes a very severe bump to induce a slight knock.
Interested to hear the results of the new bolts as I am still tempted to go for a set.
Spoke to a chap today about getting some made up. He mainly produces parts for motorcycles, but in his opinion the bolt should definitely fit the bush with only a clearance of a few thou, and anything else is just ridiculous.
He's offered to make them at the end of the second week in January when he's running something similar. Not got a price yet, so I don't know how it will compare with Staffordmike's quote, but I don't think it's going to be horrendous.
He came across as a bit "old school" which I like, so I'm going talk to him again in January and get some made up. Either way bolts that fit properly have got to be better.
Staffordmike - do you want to wait until January to see what price I can get them for?
For info on new part number check my post above.Please take a pic if the label on the shock if poss. Would be good to know the new part no info.
