Keyfob swap
Keyfob swap
motionlines
Does anyone know if it's easy/possible to change the key fob (as attached) to fiat 500 key fob? will the board and key fit?
Thanks.
by that i mean to change the current key fob shell which is pictured above to the one listed below:
thanks, though sounds more complicated then i thought it would be )
maybe at some point i'll order a shell from ali express and if it works fine - i'll update the thread.
It is not complicated at all :)
I did my own, my car didnt come with a fob, but i new it had the stuff inside the car to support one, they all left the factory with c/locking and remote antenna.
So i bought a 2nd key, re-cased it so its like brand new, programmed the remote fob using MES (registered version) and got my car security code from Sturgess Fiat for £12.50 + vat (£15) to the forum.
Once programmed, i can unlock / lock / put the windows up and down with the remote, oh and open the boot.
Now i just need to get my blank blade cut.
I am sure the remotes use the same signal etc, i reckon its just the PCB and casing thats been re-designed.
