Styling KC3 Project Silver
yeah... it often happen... admins should look into source.
same thing happened to Faust's thread if I am not mistaken, as soon as the thread goes one number over in pages then it gets fixed... so keep posting!
Decided to replace my spark plugs today and thought i,d try the Denso iridium, , While i had the top rocker cover off, i noticed a slight seeping of oil from the rocker cover so pulled that off too. Quite supprised how clean the B was under the cover. No signs of any unwanted gunk. (y) regular oil changes seems to do the trick. The B feels smoother and strangely seems to sound different too since the plug change. Would reccomend them.
The reason the variator controls the inlet cam is that you can gain more power from adjusting the inlet timing than the exhaust timing. Even when you get bigger valves, it is rare that the exhaust valve diameter will be changed much if at all. Where as the inlet diameter is usually changed depending on application.
I guess it is nice because it is shiny.
barchetta mods 016.jpgPainted in between the front spoiler today, gives it a more an agresive look me thinks. :devil: and also modified the plate holder.
thanks guy's, (y)I,ve been wanting to do that for a while now, spoiler insert looks fab and i prefer the smaller plate but might just go back to having it sprayed matt black again. The work has slowed a little here too hence i havent managed to get the turbo mod done, but i can do these little mods.:D
I,d like to tint the indicaters a smoked black next, think it should just set the front off nicely and give her a more modern look.
