500 kachel uit bouwen radiator lek airco
thebull
groningen
Hallo, is er informatie over hoe je eenvoudig een Fiat 500-kachelhuis kunt bouwen?
Kachelhuis verwijderen en makkelijk kun je niet in één zin zeggen....
Translation: Removing the heatermatrix and the word easy can't be put in the same sentence...
I think there is a write up in the Panda section, but it involves removing the doors and taking out the complete dashboard including it's steel frame.
gr J
Replacing the  heater matrix is a straightforward diy fix the ac evaporator is a whole different story, i replaced ours several years ago, hardest part was the pipes at the bulkhead and the possibility of the bleed valve head snapping off?
thanks for the information, but the air conditioning heater is defective, do I have to remove the entire system, or is there an easy way to do that?
