jjacob
Just placed a big order with FD Ricambi https://www.fiat500ricambi.com/
758 euros! 133 of that is shipping. This will bring my total parts orders to around 1000 euros. This will completely rebuild the engine and transmission. 30/70 cam ordered from supplier in Italy for 170 euros (includes 45 euros to ship).
While waiting for the parts to arrive I will be solvent cleaning parts, soda blasting some engine parts, get some repairs done to the old FPS aluminum wheels I bought out of Germany, get the 145/70R12 tires mounted, have the cylinder head rebuilt with the larger intake valves and all new valve guides, springs, and valves.
1x :Starter motor lever rubber, Fiat 500-126-600 (DS1021)
1x ressure plate (IT), Fiat 500 R-126 (KP1003)
1x :Sump cover- aluminium 3.5 litres neutral (MO1002)
1x :Engine decompression hose, Fiat 500-126 (MO1004)
1x :Crank bearing timing chain end STD, Fiat 500 - 126 (MO1008)
1x :Fan aluminum, Fiat 500-126 (MO1016)
1x :Oil filler cap rubber, 500 F-L-R-G (2.serie)-126 (MO1026)
1x :Seal segment main bearing timing side, Fiat 500-126 (MO1367)
1x :Oil pump gears 650 cc (2x), Fiat 500 R-126 (MO1382)
1x :Valve cover standard, Fiat 500 F-L-R-126 (MO1402)
1x :Engine gasket set 650 cc, Fiat 126 (PK1019)
1x :Gearbox gasket set, 500-126 (PK1028)
1x :Seal in front of gearbox, Fiat 500-126-600-850 (PK1032)
2x :Stud exhaustmanifold / engine head, Fiat 500-126 (UL1002)
1x :Engine room cover, Fiat 500 (excl. Giardiniera) (US1272)
2x :driveshaft flexible coupling, Fiat 500-126-600 (VB1004)
1x :dirt protection gear lever to gearbox (VB1026)
1x :Repair set gearbox 1st and reverse gear, Fiat 500 R, 126 (VB1034)
1x :drive shaft set A-quality, Fiat 500 F-L-R (VB1060)
1x :dirt protection gear lever to tunnel (VB1094)
16x :Wheel bolt M10 x 1.50 (lg 25 mm) (WL1145)
And so it begins. Here's a pic of the wheels I posted sometime ago.
I am going to make a separate post about my experiences in ordering parts from Europe to the USA and some comments about some of the suppliers and their web sites. Should be valuable to those in North America.
John
John
