Full throttle in 4th gear boost is fluctuating plus or minus 90mbar(max).
Is this normal?
If it isn't normal what could be causing it?
Is this normal?
Full throttle?! You'll be throwing the car around like an F1 driver soon...![]()
sorry shades i work in psi!
anyway 33psi desired and its fluctuating between 32/34psi so thats roughly a 3% fluctuation... is this not 'acceptable' due to mechanical wastegate operation?
(yes i know i dont own a turbo lump)
VGT's only have Variable Geometry on the compressor side as far as im aware. there is still a need for a wastegate. i didnt realise they were VGTs on the dizzles... id suspect there is DEFINATELY scope for a 3% fluctuation in the controller for the vanes. youll probably find that the wastegate is working properly and this fluctuation is due to the reaction times of the vanes rather than due to the wastegate operation.
im not confirming or denying you have an issue just pointing out that IMHO 3% wouldnt be a reason for concern in an OEM setup for me!
edit:- just read wiki and it would seem WG isnt required! World 1-0 Stain
ur asking a man who drives a 1.6 petrol LMAO
Uploaded with ImageShack.usif you logged vnt as well i would imagine its opening and closing to match boost.
accuracy wise i had a logging day a while ago and found most runs i thought would look similar didnt on graphs.
i thought you were remapped shady? 2314mbar=33.56psi-14.5psi =19psi isnt that standard boost?
i looked back to your earlier post on map failures and your desired boost was approx 2100mbar back then i think so maybe your std boost was 15psi and hes lifted it to 19psi.
looks like the extra fuel is causing the overboost as the vnt is close to fully open at 25% as the turbine overspeeds the boost spikes.
when im driving i rarely see overboost but when testing and logging its always driven harder so it always looks worse.
i finally managed to read my map with galletto but so far have only identified (guessed)half a dozen of 153maps on winols
and i also think yours is probably 2500mbar map
