Two things really helped me there: (1) I was taught to drive in snow -- pull away with minimal revs, maybe in a higher gear than normal; avoid using the brakes (use the gears to slow down); and do everything as smoothly and gently as possible with lots of planning and anticipation: and (2) that car has all-season snow tyres on it.wow I am amazed by how much grip you seem to have. I know the 4x4's are raved about and now I see why. The fact that you can drive at a decent speed and not be sliding anywhere. Thanks for the videos
Pete, one of the joys of driving a 4x4 is booting it in 1st from a standstill and realising that there is no wheelspin and that even the fastest sportscar could not keep up with you.Two things really helped me there: (1) I was taught to drive in snow -- pull away with minimal revs, maybe in a higher gear than normal;
It was the 'massive amount' I was referring to. The snow (on the road in your pic) doesn't even reach the wheel rims, and that on a Panda with low profile tyres. In places, the Hertfordshire snow was brushing the 4x4's sump gaurd, so that's over 6 inches depth on the roads... (although I gather rather more snow fell further north later, so in the end you may well have had more than we did 'down here')What is it then?
Indeed -- stopping, and also cornering. Even a 4x4 still gets very sideways if you're not careful. Hence the need to do everything very gently...The biggest problem with a 4x4 is that the incredible traction misleads you when it comes to braking. You can pull away like a train but stopping is still difficult.
Even if you only have 2WD it makes sense for your car to be pulled rather than pushed, goes back to the days of horses, did a horse ever push a cart.
Rear wheel drive only arose because of longitudinally-aligned engines and the lack of engineering skill to transfer power to the front wheels. That those wheels also had to steer also made it difficult.
BMW and Merc continue to live in the engineering dark ages.
...especially the Postman Pat 'hehe' we heard when you saw the two mountain bikers...![]()
Totally agree. I have had many 4x4's and the grip out of a junction etc is amazing. You can squeeze out in the shortest of spaces.
I once had a Celica GT4 (1995 one of the latest ones) with 280 bhp.
That off the line was amazing.
Revs to 6000, dump the clutch and you were gone!
I used to do that everywhere until it needed a new clutch. Toyota quoted £1300, engine out job
Still, when the clutch was in, I did it some more, cos it loads of life left then!
Oh, what it is to be young and carefree!
