Technical  Intermittent brake issue...
strudelpus
Hi folks,
Brake pedal sporadically really spongy going to the floor, but immediate re-application has the normal firm pedal feel. Servo vacuum hose looks fine and no apparent leaks/fluid loss. Wondering if an air bubble is floating around the system or an issue with master cylinder internals. Perplexing intermittent fault...:confused:
nothing to do with the servo or vacuum side
its hydraulic
air is mostly entering the system via a weeping cylinder, calliper or master
you could try bleeding to see if any bubbles point to corner of the car.
its hydraulic
Most likely to be master cylinder from the limited evidence given here? A damaged seal, or especially one which is reversing itself (not common but I have had experience of one doing this) could give this.
you can boil the fluid if one of the brakes is dragging but you should be able to smell it
or its not failing on long descents with hairpin bends or when driven like you stole it ?
If the pedal goes down all the way when you press very gently and locks at the top when you stamp on the pedal then its the master cylinder
It doesn't so much Lock at the Top, more immediately reverts to normal operation, but thinking about it i agree that it may well be an internal master/cyl seal folding over and reseating...
Thanks for the input, folks!
10 minute job thats worth checking
Take the rear drums off and check the shoes linings haven't fallen off
normal they lock on when reversing but as they move around the pedal feels different.
Its fairly common with the original Bosch assuming is not a rear disc model
while there its worth checking behind the rubber seals for weeping. A small amount will not be the problem but will need changing
Check the brakes and hoses, especially rear drums. If they are all OK then it's likely to be the master cylinder.
The plastic covering on the metal pipes tends to expand under the flare nuts. Warm them with a gas lighter flame and they'll unscrew without twisting the pipe. Seal the now bare metal with grease. If the pipe is really bad, replace with a long braided hose from the underbody connector. This removes the metal and rubber hose in one job.
