General  intermitant starting proplem
aberaeron
this will get you thinking ,just changed starter motor on my marea 1.9 td as it sounded tired,(168,000) new recone starter went to start battery sounded dead or very low as in starter just clicked and interior light dimmed:confused:right just for luck tried again vroom it started no proplem ,now it has done this a few times now and it's p###ing me off,there are nothing out of the norm dashboad wise all is ok and it has new glow plugs it does it hot or cold :mad:now could it be an engine earth proplem or am i missing something:cry:
check the battery terminals are clean and also check the earth strap from gearbox to chassis is not frayed or corroded, especially at the mouting points.
well believe it or not bulldog hit the nail on the head dodgy ebay starter,striped it tonight and freed up the shaft with the dog on the end,main shaft it now moves fingers crossed it works ok tomorrow any one know what the black box next to battery is it's not the one in front with the fuses in but the one at the back below bulkhead side ,think i have seen one on a pug td but not sure
Here you go, the diagram on the right :)
well it did'nt work put old one back and touch wood(grabbing my head) it's working after a good clean up ,thanks for the diagram evil marea is that on the work shop manual that you can get on ebay:idea:
Think it is the same one :idea:
I downloaded mine through a torrent shhhh ;)
Trying to think of a way to get it to you. The folder is over 380 mb
