DualogicFan
Hi everybody.
My car has the seemingly common LCD screen problem, where speedo itself and tachometer on the side work fine, but pixels are messed up (so I cant see engine temp, how much fuel I have, what gear I am in etc).
It is similar to this recent post: https://www.fiatforum.com/threads/instrument-cluster-help.522732/
My car is 2013 1.2 51kw Fiat 500 with Dualogic gearbox. Manufacturer code on the speedo is 735516033 and OEM code 503005214430 . Code on the LCD (on the ribbon) is COG-VLIT1318-01 . These parts could not be sourced anywhere so I can't have a direct replacement.
So what I have gathered during my research into this issue is that the best solution would be to buy a digital speedo from a Dualogic car that would be still prefacelift (so up to 2015 and 2015 maybe included?). I found that minitools sells new clusters like this one: https://store.minitools.com/en/dash...-new-instrument-cluster-sei-qs-735483644.html
Also there seems to be some aftermarket replacement like this: https://www.aliexpress.com/item/100....25!!!!!@2140ec5d17742562138558108e7843!!im!!
Price is a bit higher and it looks cheaper, but would still work for me. The key thing for both of these is being able to support Dualogic (to show which gear is currently selected).
My question would be that does anyone have experience with these clusters (minitools or aliexpress ones) or does anyone know the exact cluster code that would suit my car? Or if there is some parts catalogue so that I could find instrument cluster code for 2014 Dualogic car for example? I think that if there would be a solid solution for this issue then it would help a lot of people since it seems to be a quite common problem on these cars.
Many thanks in advance
- Model
- 1.2 51 kw Dualogic
- Year
- 2013
