mickywillis
2 weeks ago my wifes 2004 Stilo diesel Active Multiwagon showed the classic symptoms of the cluster failure issue. Removing fuse 53 and replacing livened up the panel for a few minutes and then went back to failure mode again. No lights, speedo, rev counter, LCD display showing, only the airbag warning lights.
Sent unit to a cluster repair agent and collected yesterday. Plugged in and all good (so I thought) Refitted dash and went away happy. Didn't drive car at that point.
Used the car about an hour later and whilst all still good, when I drove off the speedo needle moved from rest (zero) to 140 MPH (in other words full scale deflection FSD) The needle moves as soon as the car reaches 2 or 3 mph, both in forward and reverse. When coming to a stop, the needle returns from its FSD position, back to zero.
Tried removing fuses to reset cluster and everything works except the speedo? The odometer is clocking up distance, so can I assume the road speed sensor is OK?
Unit sent back to repair agent and they inform me it is OK?
So where do I look now if the cluster checks out OK? If the odometer is clocking up mileage OK, does the speedo pull its signal from the same sensor?
Car is ABS equipped and prior to cluster failure, the speedo worked fine, so I'm not convinced that the cluster still isn't faulty.
Could it be an issue with the ABS sensors on the front wheels or is there another sensor for the road speed? If so, where would it be located?
Thanks in advance.
Thanks in advance.
