Thanks for the reply. Its just a univeral twin cone filter. Im going to the scrappy at the weekend for a hose to connect it up. Heres a link to the filter
The top half off is much simpler, as when i went fully custom, i had to take the light out, bumper off, make custom fittings etc...
you dont need to disconnect the battery
loosen or break the hose clips, depending on the type
loosen the 4 phillips screws on the airbox. Disconnect clips on the battery tray for wires and hoses connected to the air pipe
remove the hoses, filter and top of box
refittng is the reverse. Use new hose clips
Well For the hose ive seen pics of kits installed using the hose from the intake that connects between the main intake scoop thingy and the elbow at the bottom of the std air box ( donno what to call it! )
So im gonna try that and see how it goes!
