Aspect
The problem being a lack of power to the HU, now am i being stupid here? Do i need a wiring adaptor? Head unit is an Alpine 9855 going into a 1.6 Dynamic.
custard boy said:hmm cant find it but ive seen it posted.stilo guy will know for sure![]()
Who are you?custard boy said:see you couldnt find it eitherbut i swear theres a thread on this issue
bozzy said:There should be a yellow cable coming from the rear of the head unit that appears to be surplus. This needs a live feed. If there is a spare red coming from the vehicle loom then connect this to the yellow wire. Try that.
Aspect said:Its all connected up, i made sure i had the yellow to yellow connected aswell. Press the old power button and not a sausage![]()
bozzy said:Try connecting a red cable to the yellow cable.
Bo~Select@ said:You only need to swap the battery live and the ignition live (Yellow and Red) over to get it to work with the fiat loom.
Or try red and yellow from the head unit together into the battery live.
Aspect said:If you mean plug it into a cable in the car, there are none. Theres simply the 2 blocks and the aerial. Should there be more cables?
bozzy said:Can you get a photo?
Aspect said:Ill try mate, where in birmingham are you from? I saw a yellow Stilo earlier![]()
