inlet studs
inlet studs
bigfattank
cumbria
Hi I'm looking for studs and nuts to attach the inlet manifold to my 1.2 16v and theres no way im paying fiat over £70 for them!! lol
is anyone breaking one or know where I can get them?
I need M7 x 1.00 studs and nuts quantity 10
cheers for any help, much appreciated :)
Jon.
nope certainly not on this engine, its out of a punto sporting 1.2 16v 6speed
definatly m7 x1.00 and takes 11mm socket to undo the nuts
the exhaust mani has m8 studs though
How about using a set of suitable bolts threaded all the way along?
With the nut close to the head, saw the head off and slowly work the nut over the sawed off edge.
Better still if you have the room to work, with the nuts on the bolt, use the heads to tighten them into the block first then cut off the heads.
