engine coolant sender is at the rear of the engine near the cam belt cover. inlet temp sender is in the throttle body i think. I'll just check that and get back to you
oh I see, There have been some threads about these mods before. The general thoughts are they are not much cop. it fools the ecu into thinking the engine is cooler than it really is and so enrichens the mixture. Fuel consumption increases and it won't pass the mot whilst fitted. Other than that I don't think they do any lasting damage. Start a new thread more relevant to what you want to do and get reaction on it.
Nothing wrong with the question at all mate.
My brain was not working on the same wavelength, if you had said
I'm thinking about one of these resistor thingies then I would have known that it was the fueklling sensors you where looking for not the temp guage one. I should perhaps of twiggede by the second part of the Question about the Inlet temp sensor.
But hey sometimes I'm not perfect.
all good fella thanks for your help anyway. actually while i am asking do you know if there is a temp gage you can get for the sporting that can be fitted so i can see how hot the car is getting?
And then overfuelling can lead to breaking up your catalytic converter, which is fairly expensive to replace. I know, because my IAT sensor went wrong and was working between 30 and 40 degrees whilst cold. Now looking for a new sensor
