General  Injection system and fuel ⛽️ Cleaner
elbahey
egypt
Hello Everybody,
I am a pharmacist and i have factory for chemical and cosmetics .
Recently I owned Fiat Ducato for my business tasks ,
I have face alot of problems concerning injection systems and get rid from it using Injectors additives formulas ,
There is a shortage in most of this item in our local market,
So i am arranging to develop and produce fuel and injections cleaner to be added to the fuel ⛽️,
Could anyone suggest formula or main ingredients of this products to produce it in commercial use ,
Or can connect me with Experts in this industry
Thank you all for your usual advice
Pharmacist Bahey
I am not fuel chemist. I doubt if there are any lurking here. a simple search gets. Additives are intended to do a multitude o f things and contains blends of chemicals for different purposes. diesel fuel contains a small percentage of dissolved water measured in parts per million (ppm). Too much water causes problems like fouled injectors, poor combustion, and blocked fuel lines due to frozen fuel in icy weather. Pouring a bottle of diesel fuel additive removes suspended water from the fuel and prevents the diesel from coagulating in winter.
In addition, diesel additives contain detergents to keep the injectors clean, while some have ingredients to boost the cetane number for smoother idling and easier cold starts. Diesel additives could provide a slight performance upgrade depending on the product, but their primary goal is to clean the injectors, remove water, add lubrication, and improve the diesel's thermal stability.
I recently read an interesting article on additives that was more in depth but i doubt theres a diy additive recipie out there other than 2 stroke oil.
