General Induction Kit Help
beswick0203
Hi I just recieved my induction kit for fiat punto 1.2 8v. Having a look online at the kits, it appears that im missing the the thin pipe as you can see on the picture below. Do I need it?.
yes you will need it, message the ebay seller saying you have not recieved it, they should send you 1 out or even give you a refund!
what you could always do is, there must be some sort of industrail states around your house just pop in and see if you can pick up 0.5m of hose pipe and use that! you will also need to hose small clips
If the metal pipe has a branch off for the breather then put a pipe to it. If not just put a small breather filter on the rocker cover.
As the others have said, thats not the best place to have the filter, you want it at the front, but away from the exhaust manifold.
