Technical Indicator Lock / Unlock Setting
Wrexham, North Wales
Twice now my 500X has lost its indicator blink on lock/unlock.
There appear to be no reason or event that makes this happen but if it happens to you then it is easily fixed.
Go into the uConnect Vehicle settings menu and you will find that the blink setting is set. You have to un-set and exit right back out. Then go back in and set it back on again and exit back out again.
This could be an indication that my battery (original over 3 years old) is on its way out but not other functions are affected, no random warning messages, etc. so inconclusive.
Oddly my Visual Studio Development system lost it's editor navigation bar despite it being enabled in the settings menu. Same as for the indicators the option was enabled and cycling through the disable and then enable restored the expected behaviour.
So if your car throws a wobbly on and function/setting the fully cycle that setting before panicking.
Ours does this on occasion despite the option being set - Works one moment and not the next lock-unlock - perfectly Italian!
