Technical Indicator continues after turning
Nottinghamshire
Afternoon everyone,
My 2011 Punto Evo has a somewhat minor but irritating fault, roughly 80% of the time when using the right indicator, after completing the turn (or turning the stalk off manually) the indicators continue to flash 5 times as though you've just used the lane change feature on them.
Never happens on the left one, and having tried there appears to be no pattern to either turning the wheel back to the straight position gently or vigorously.
Just wondering if there is something to know about before taking the long and potentially headachey road of replacing the stalks.
Many thanks!
mine does that as well, although it's a bit different, mine sometimes after switching off the indicator goes on to blink the other way 3 times or so. This is probably wear on the switches seeing we also have around the same mileage. I will keep following incase this is a common issue.
