Technical  Improving AC cooling ?
Main thing is to have your freon level checked.
Most ac systems will leak freon even though they are new.. most of the loss is through the seals which tend to dry and crack with age.
If thats okay wash the condenser with a high pressure garden hose when the car is cold, (usually located around the radiator in front of car), if this is blocked it will not allow the freon to cool correctly.
If that don't help wash the evaporator, you will have to by a special coil cleaner and have to foam it in the air intake.
If that dose not help its going to be more complicated:idea: ....let me know how things go.
[FONT=arial,sans-serif]The evaporator provides several functions. Its primary duty is to remove heat from the inside of your vehicle. A secondary benefit is dehumidification. As warmer air travels through the aluminum fins of the cooler evaporator coil, the moisture contained in the air condenses on its surface. Dust and pollen passing through stick to its wet surfaces and drain off to the outside. On humid days you may have seen this as water dripping from the bottom of your vehicle
Fommy:slayer:
[/FONT]
