so a little has been done.. im still collecting parts and it actually feels like progress is slowly being made...
after realizing the 'spare' wasn't there:bang::bang: i went on the hunt for a p75 fuel rail... unfortunately nobody wanted to sell me one for whatever reason and i couldnt find one for sale on its own.... but fortunately this came up at a reasonably extortionate price....:yuck::yuck: i must just be tight but £60 and it was delivered to my door (thanks puntospares, the guy is great and had it very well packaged and in my hands th next day) i didnt need the inlet or the tb but to be fair theyll come in handy as spares one day... maybe...
so thats the main 'hard to get parts' all sorted now.. hopefully things will be a bit more plain sailing now..
so...
ive been trying different things to try and clean this head up before it goes to the machine shop along with the block and gasket to have the c/r measured, calculated and adjusted
so far ive managed to kill off a can of brake and clutch cleaner, a can of nitromors, a bit of petrol.. some parafin and a bottle of fallout remover... the head is still an oxidized mess in places but its a little cleaner then it was before, next plan of action is to cut up a 20l drum and fill it with phosphoric acid mix and see how well it comes up with that,
the head in question
the valves removed and cleaned up with wire wool and a drill :devil::devil:
they will go away with the head and have the 3angle seats cut and 30deg back cut on the valves.. and then when i get them back ill give them a clean and a polish possibly
a fresh gasket kit from s4p and bolts to match... im not 100% sure on the bolts as they were sold as genuine fiat ones which they clearly arent and ive ony every used payen or genuine bolts before... anyone ever heard of them or used their parts before??
this also became part of the collection...
and Ryan (not sure of his ff username) very kindly built the loom for me, however after close inspection it seems the main loom connector has been damaged at some point.. and as i called the main uk supplier and was told he couldnt supply but could make me a 30cm loom and charge me £35+£8 postage i thanked him and declined....
so off scouring ebay and i found these (for some reason a fair bit cheaper on their website, maybe extortionate p&p to make up for it or something)
http://shakmods.com/shop&#!/20pin-Psu-Connector/p/36714180/category=3316059
ordered in blue of course
and the pins to match
http://shakmods.com/shop&#!/ATX-PCI-EPS-Female-Connector-Pin-Set-10-Pack/p/14152408/category=3316058
and the pin remover to hopefully remove the pins from the connectors and possibly salvage as much as i can
http://shakmods.com/shop&#!/Shakmods-ATX-EPS-PCI-E-Removal-Tool/p/23562758/category=3316063
hopefully on monday the engine will be off to the machine shop, in the mean time i need to get the inlet, tb and fuel rail cleaned up and order the paint for the entire engine..
i need to order some screened cable for the cps (if i cant work out a way of stealing some from one of the many looms laying around in the spares room)
i need to source and order a 3bar map sensor and a 3way boost solenoid
i need to source and buy a slightly smaller intercooler (its waaaay too big for the power i plan on running)
i need to source and order some bolts for the inlet manifold, have the inlet modified and the servo take off moved
i need to source and order some stainless exhaust side studs and nuts
and i need to get the cam shimmed into the head (once ive found the bearing caps and oil spray bar
) and find some 120mm stainless pipe to make the throttle 'bob' (@jatkinson is also gonna measure his bob 'OOO ERR' so i know what height i need)
then i need to go scrappy hunting for a set of biggger injectors.. after ve done some research...
that should about complete the inlet side of things... ish...maybe... most likely not...
hopefully more progress soon
opinions, input and advice always welcome
cheers
lee
