Hi all,
Something strange happened last night with my Uno Diesel. I will explain it below. Would be great if somebody could make an educated guess. I'll try to be as detailed as possible.
I drove my Uno to this restaurant and parked it just nearby. I walked out and bought food and came back and sat in it. I switched the ignition on just halfway (so that the heating coil light is on) and waited till the heating coil light switched off. I noticed that I had forgot to switch off the indicator when I had parked. so I switched that off. Once the heating coil light was off, I gave a twist to the ignition and there was this click sound (some electrical relay making contact) but the engine didn't respond. The lights in the dashboard were all coming up so I concluded that the battery was fine. But the engine didn't start. I switched it completely off and tried again. Still the same click.
I waited for around 30 seconds and tried again. but still it didn't respond. tried 5-6 times. no luck.
Just to make sure that all electrical connections were alright, I switched on the blower. it was working. then I tried the ignition again and the engine started just fine as if nothing was wrong with it.
After that I went home and switched off the engine and tried starting it again. and it worked fine.
Any ideas why this strange behaviour could have happened and should I show it to the mechanic? how will he reproduce the same problem? now it is working fine. I am worried that it will behave the same way sometime and I will get stuck somewhere.
Devakanth
Devakanth
