I have literally just done mine within the last two weeks . I used a Gates kit complete with , belt , both idler wheels , and a new tensioner . The kit is widely available , if not a little expensive . My local motorist centre , sourced this without issue . I could get the part number , but this method is extremely dangerous , and something i would never recommend to anyone . It is a vital part for the engine , and should a mistake occur , it could prove terminal for the engine .
And yes , you're quite correct the JTD engine does use a different belt to the IDTD . I believe the Jtd water pump is driven by this belt , whereas the Idtd is not , but i can only confirm that the Idtd water pump is not .
If you van is a left hooker , then yes it is highly likely , a vin number will likely be required . Mine was imported in 2006 , despite a 2000 build , originally with a German registration plate . My new British plate has never shown on any part's computer , as i'm guessing , it's not the original registration mark .
