Since i installed my sub and amp I have had nothing but problem after problem with it. The re-occuring situation is the squeeky speakers, mainly coming from the 6" x 9"s. I was told this would stop if I moved the main red lead (running from the battery) away from the blue wire (the double wire that runs from the head unit to the amp). However after doing this the squeeling is still occuring so i'm guess it can be a number of things now...
1. Not earthed correctly?
2. Not attatched to batterly correctly?
3. The wires are in need of a change since the plastic is coming away and showing the actual wires?
My most recent problem started yesterday. It a very strange noise, which can only be described as the same sound as when you are tuning into a radio and you half get a channel and it sounds erm 'alien like'. This seems to be coming from my 6" x 9"s.
Can anyone point out the possible, if not the exact problems and give me some ideas on how to correct it.
Thanks in advance....
