F R O S T Y said:
Yeh i know what you mean mate but i have just the one amp running 2 subs.
I meant that IF you had more than one amp, you wouldnt want your HU turning off the remote feed because you may have more amps running other speakers (components for example). Say you were running a 6 channel setup... You have 2 subs bridged occupying 4 of the channels (2 each) and a set of rear components on the 5th and 6th. If you turn the sub bit off the HU, you wont want it to turn the amp off otherwise you'd loose your components.
I know in your case all your other speakers are run of the headunit, but if you had extra components/coaxials etc off other or the same amp, you wouldnt want the HU turning off the amps, if you get my gist.
Basically from what you said, turning down the bass (muting it in effect) would cut the bass out of the system, but the amp will remain on. From my experiences, this is totally normal. Basically the amp remote wire is live all the time the actual HU is powered on. It will only switch off when the HU is powered off.
F R O S T Y said:
all other speakers run off the head unit. And you was right because i just tested my old sony head unit just now and everything works the way it should. So that now leaves me with a pioneer head unit that only runs my car speakers and no subs
any ideas as to what could be wrong with the head unit to do this and if it would be worth fixing it or shall i just get a new one now?
You lost me here now. You dont have any subs, so your amps arent turning on? If they are turning on and operating as above, then again i would say thats normal becuase of the reasons stated above. So a new headunit shouldnt be an issue really.
F R O S T Y said:
Well gutted because i love that head unit, its worth 400 quid from halfords but i paid 120 for it through a mate. :'( p.s what head units do you guys recommend, i'm thinkin about an Alpine one now but i'm skint lol
F R O $ T Y
All down to personal taste. I like my sony, it does what i ask of it - so really hard to recommend untill you know what you want from your HU
EDIT:
Just re-read a few posts above and i see your problem now
Yea, definately a suspect HU. You need to see if the sub's volume hasnt been muted or lowered too much by accident, and that they are sending out a signal properly. Sounds silly, but try resetting the unit properly (with power on and pressing reset button) then disconnect it and let stand for a while. You'll loose all your presets, but sometimes cures little bugs like this too
