i pod connection
i pod connection
william cruickshank
scotland
i have just bought an 09 bravo not a bad car but i asked the dealer about fitting blue n me one dealer said it had to be fitted in the factory as it was pre registered if i cannot get it fitted what is the best way to get ipod touch hooked up to the cars hi-fi :)
Hi, you have 3 options. you can either get an aux in cable from fiat (or ebay etc), a different head unit or you can get an FM transmittor. The last one is the cheapest (between £12-£30) but is also the lowest quality. I went for one and it's ok, but not great.
I asked the dealer (evan's halshaw) about an aux in cable, and they quoted me £150 fitting. Should be ALOT cheaper on the web if you can fit it yourself so good hunting!
A new head unit will set you back about £80-100 ish for a decent one with aux in on the front (3.5mm jack) + USB port. Some of the more expensive one's will also control your IPOD throught the head unit. You'll need to fit a bracket and it won't look as good as the original FIAT one in my opinion.
There are a couple of threads (i think) about head units and the aux in option, so you might be able to find a better answer around here somewhere.
Whatever you decide, good luck (y)
Dude why dont you just get one of these!???
It does EVERYTHING the B&M kit does... and more, not to mention better!
Got mine installed in the Bravo a few weeks ago cause i couldnt bare the FM Transmitters crappy quality, and was a bit OCD about changing the HU to an ugly aftermarket halfords one...
http://www.parrot.com/uk/products/hands-free-car-kits
Hope this helps!
