Don't be getting gearbox and clutch mixed, two separate components really Lol.
Fair point
GP Sports had 8v's not 16v's AFAIK.
I love my 1.9 150 Sport but as said before the gearboxes arent the greatest. Ive just had to replace my clutch (with DMF and other things). Wasnt cheap at-all but now car is spot on!
grande sport has 130 bhp not 136
You mean I've been driving my car for 4 years and 9 months, and never got into top gearI'm 99.9% sure that in the UK all Bravo's have 6-speed boxes.
I'm 100% sure my car has only 5 forward speeds, as do all 1.9 Mjet 120s![]()
What is the big difference between having 5 gears or 6 gears? (And dont say one more gear) I always thought having a 6th gear would be better for pulling at the top end and better too cruise in.
I'll let you know what the two version I test have once I've got them.
You're all wrong about the benefits of the six gear.
Having owned the multijet 1.9l 16v with 6 gear, the 1.6l with six gear and my 1.9l 8v bravo with 5 gear, I can tell you that the 6 gear gearbox is pure crap compared to the 5.
Here's why:
-The gears are harder to shift with the 6 gear especially the reverse gear.
-You spend your time shifting gears because the gear ratios are shorter, it's annoying in city driving
-Since you lose speed and time at every gear change, one less gear makes for better acceleration.
-Also not sure but all the sticking and noisy gear problems I read about lately on the forum are 6 gear, never heard of a 5 gear having issues.
- The sixth gear makes absolutely no difference in fuel consumption in real life conditions.
6 Gear would make sense in a petrol car, but It's absolutely stupid in a multijet with all its torque.
the gears make a lot of difference, the 5th gear in both cars on the bravo ie 120 bhp and the 150 bhp models is around 30mph/per 1000 rpm. then on the 6th gear versions your top gear is around 35mph/per 1000 rpm, big difference. and at speed big difference in cruising.
120bhp model does 60mph at 2000 rpm, where as the 150bhp version does 70mph at 2000 rpm.
So it sure does make a difference in cruising mpg, if you were to fit the 6 speed box to a 120 bravo your mpg would be better at any speed above 60 mph..
Also the 6 gear model can handle far more torque than the 5 speed model, maybe you don't hear reports of failures of the 5 speed model because its max torque is pretty poultry for a diesel, at 188ft/LB of torque. even the punto grande with the same engine [1.9..120bhp] has the 6 speed box and indeed more torque than the bravo 1.9 120 bhp.
Diesel with their short rev bands compared to petrols cars benefit from having more gears after all it is in modern diesels where 6 gears became almost standardized across the whole sector, the only reason the bravo 1.9 120bhp got a 5 speeder with a shorter top gear was because otherwise the replacement 1.6 mjet that was already in the pipeline would not have looked such an improvement in the CO department and therefore bragging rights as being 10% more economical ..
Nope, 6th gear is just a gimmick so that clueless people who look for a car don't discount fiat as a lesser car for having one less gear and it also helps with the stupid European bureaucracy that requires more fuel economy NUMBERS (not real life fuel consumption, just theoretical mpg numbers like you're referring to)
If more gears was a solution for performance and consumption we would all be using semi truck gear boxes with 12 gears.
I'm talking out of experience, and I wouldn't take a 6 gear diesel unless it's merc of bmw with over 250bhp
With the genuine greatest respect, sorry but this is just plain inaccurate information on so many levels. Also, you would only take a 6 speed if it was on a Merc or BMW with 250bhp, why? Do you actually know how gearboxes work because that sounds like its just heresay you have plucked out of the air.
You seem to think that the 6th speed is only an extra ratio that makes going down the motorway more economical,
Em, point me to where I said that...
Oh right, sorry it wasn't you... You actually didn't say anything constructive or explained your point of view, let alone advise the op. You just drop by to say someone is wrong for the sake of it.
With all the genuine greatest respect of course![]()
Please, you are wrong on all accounts, firstly having a tall sixth gear does not help how do you put it those euro bureaucrats with gimmictkry fuel figures as sixth gear is too tall to be used on most of the fuel cycles, and only comes into its own at higher speeds, as i have already stated ie 60 plus mph with regards the Bravo diesels.. Its quite a simple thing to work out for most intelligent people again as explained before, but maybe i might make it a little easier given your lack of understanding,which is clear given your last statement, ie. bmw/merc over 250bhp, bla bla bla, which means nothing really without knowing the rev range of said cars and what gearing spread works best. so in simple englishNope, 6th gear is just a gimmick so that clueless people who look for a car don't discount fiat as a lesser car for having one less gear and it also helps with the stupid European bureaucracy that requires more fuel economy NUMBERS (not real life fuel consumption, just theoretical mpg numbers like you're referring to)
Two words here: driveability and sizeIf more gears was a solution for performance and consumption we would all be using semi truck gear boxes with 12 gears.
