Technical I have a leak, but where from?
tjordan
London
Hi all, just noticed this patch of fluid from a leak underneath my Panda. Does anyone know what part this is? I've been having issues with coolant running out far too quickly so could this be related? Many thanks
If it's coolant
Look.around the core plugs under the spark plugs
And under the hoses by the thermostat
However the drip that's about to fall looks like oil
If you catch a drip on some kitchen roll is it brown or red
If it's coolant
Thanks just done this, it's brown so looks like it's the oil...
Great
But still bad news as the coolant loss needs addressing asap
Brown could be gearbox or engine oil
I assuming it's a manual gearbox
Put your finger in the inspection hole at the top of the bell housing is it wet on the inside, you might need to move some hoses aside to find it
Look under the selector lever
Check around this part
Corners regularly fail, in my experience back left if standing in front of the engine
Sumps can also get pin holes in them
No doubt someone will be along and suggest a sniff test to identify if it's engine or gearbox, I have a bottle of each here and I can not tell any difference between them
Normally end up cleaning the parts up and watch for the highest point where it first starts to appear
