General hub nuts
General hub nuts
DRIVE ME CRAZY
swansea
hi everyone can anyone tell me what size the hub nuts are front,and back so i can buy the appropriate sockets,also the torque settings for them thanks. ( 2004 stilo diesel est)
Can confirm from experience that they are 36mm, the problem is then the size of the bit. Thanks to the design with the nut in the middle of a protruding metal circle, too thick of a bit will not fit, so be careful with that. I ordered a Draper impact bit and it was too thick FYI. I can't remember who made the bit that did eventually fit, sorry :(
Good luck (y)
I'm 99% sure the front nuts are 36mm on the 3 door, 5 door and Multiwagon.
But the size of the nut on the rear of a 2004 Multiwagon is 32mm, not sure about the 3 and 5 door versions but I'd expect it to be the same.
Here's a couple of photo's of a 2004 Multiwagon rear stub shaft with nut and washers. Popped a 32mm socket on it just to check.
According to what I have wrote down and I can't even remember where I got this from lol front is 7daNm + 62 degrees rear is 25 daNm. That's for the 1.6 though, I don't know if the rest are the same...
Edit: don't think I even have a 32mm bit, how did I get my rear off :confused:
