HTPC - Prebuilt or DIY?
arc
this is where i stand
Manchester
Hi all
In the process of overhauling my setup. Moved all my media onto a fileserveer, which is connected to the lounge via a 200mpbs powerline / homeplug.
My current 'HTPC' is a classic Xbox that is chipped and runs XBMC. It cannot play HD and I intend to replace my lovely old 37" Toshiba CRT shortly so need/want something nice to feed to a new TV.
In the past i've always built PCs up myself but realise that when it comes to really really small PCs that I might be better off buying prebuilt.
Can anyone offer me any advice.
Main function of this PC will be to play HD from the network. (optical drive isn't that important (can always cache them from the server)). I want to be able to watch 4OD/iPlayer/youtube/other streaming services on it. Don't care about games.
I do care about noise, and this system will either have an SSD or boot off a USB stick. It doesn't need vast amounts of space as it will stream everything from the fileserver. Ideally I'd have no fans, I do not want it on all the time either - so rapid wakeup from hiberation / s3 is important too. SPDIF and HDMI out is needed.
I'd quite like a dual TV tuner so I can record (may look at changing this for a satellite tuner at a later date)
I don't want a keyboard/mouse to control it, so IR and remote is required.
I have a budget of around £300 in my head.
What do you think? I've been looking at boxes like the Acer Revo. I don't know what kind of spec CPU i'm going to need for 1080p though.
I also have an ASRock 330, excellent for a HTPC, it can be a little loud however due to the really small fan. If its in a cupboard though its fine. Its running Windows 7 Ultimate x86 and using Media Center.. files are streamed from a home server, mainly use it for 720p/1080p mkv's.
I also have an Apple TV 2, this is a great device too depending on the formats you have (m4v etc).. also really good for airplay!
