racingABARTH
- Joined
- Feb 15, 2016
- Messages
- 2
- Points
- 26
Hi there,
I like to run my Soleil 899 on carbs. How do I do this? Yes I know that another inlet manifold is needed but this is not a main issue. The 899 SPi is managed by a ECU/EPROM/computer where all signals from various sensors go to. So if I get rid of the throttle body/injector house there are no signals coming from there. The engine won't run.
So how can I 'trick' the computer while running on say a DMTR, C36 PHH or DCOE carburetor? Or else; how do I fix an ignition without removing the computer?...fix a signal that has the same values as coming from the original placed sensors, in- and around the injector housing etc.
Putting in a old generation 903 from say a Panda or A112 with rotor ignition is not an option.
Grtz.
Grtz.
