Technical  How to remove cam sensor?
FatBoab
My 2001 1.9JTD Multipla is difficult to start, especially after a run, so I intend to change the cam sensor in a bid to rectify the fault.
Is there a quicker way to replace the cam sensor without going through the complete aux & cam belt removal process?
Also, if I need to take the cam pulley wheel off how can I stop it moving when I put force onto the centre bolt?
FB
Have you tried changing the crank sensor first? Poor/non starting with a warm engine is a classic symptom of a failed one. It's also a much easier job to replace than the camshaft sensor.
Hi Widemouthfrog,
Yes, I've changed the crank sensor.
FB
