How to Bleed the Cooling System
T
Tony
Hello Fellow Fiat owners.
(Looks like a great site)
The Vehicle:1996 Fiat Bravo 1.4 12 Valve without air/con.
Problem: Replacement radiator fitted, have run the engine to heat up the coolant, loosened -removed the Bleed screw on the Heater Hose.
Unable to remove an air lock = Heater stays cold, and Bottom radiator hose also stays cold.
Is there a special procedure to follow, any assistance will be appreciated.
Look forward to hearing from you.
Best regards,
Tony [email protected]
U should open the valves from A to C (D whit aircon). And pour some water / antifreeze in till it gets out on valves A and B(whit aircon), than close them; pour some water more till it starts to get out on valve C, than close the valve; and then the same on valve D. (only whit air con). That will get the air out of the system.
Sven
J
966
jason
J
P
15
12K
Dark Lurker
3
7K
Steve
S
