Technical How hard is it to install a van aken turbo?
..how come it's 2k to get it fitted?
Wonder how much Pete would charge? :D i'd be tempted to get one for a £1000, but my cinq used a fair bit so would need some reliability. Pete's black 'un sounds awesome mind..
oic, so this custom pelnum goes ontop of the throttle body?
can u run a chip along side the MF2 or would u need a piggy back chip of sumsort?
and i am guessin u can have a tricker 40mm tb on before doing the conversion?
sorry for all the questions.... well tempted by a turbo pssssst conversion, have been for ages!
Yep, second injector sits on top of the throttle body in an ally plenum.
I wouldn't run a superchip with it, it may advance the ignition timing and make detonation / pinking more likely. That's A Bad Thing.
I'm running a 36mm tb, you could run a 40 - J333EVO is.
Pischht is addictive :D
Have been quoted £45 to set the MF2 up on the rollers, but my mixture gauge says everything's hunky dory, so haven't bothered.
cinquecento_sunderland said:
you need an engine that was specifically designed for a turbo these kits are useless might as well stick a 12v fan on air intake like ones on ebay the psi they kick out is a joke complete money waist :rolleyes:
you guys crack me up
like Pete says - before you can speak with such authority I suggest you actually try an vanAaken modified cinq
a Cinq with 80 ish brake is a seriously fun tool, the high boost ones are pushing 120, hardly a joke
re this quote from sunderland
"you need an engine that was specifically designed for a turbo these kits are useless might as well stick a 12v fan on air intake like ones on ebay the psi they kick out is a joke complete money waist "
what utter ******** rubbish you are talking!
you clearly have never seen the installation or driven one, they are excellent.
indeed, i want my car to be able to do that :(
I can suprised a few though. Sat at someone lights, and set off in a hurry - had my music on loud, some guy next to me in a 2.0l Neon decieded to race. I'm not sure how he did it, but he beat my little 1.1l :eek: i bet he wasnt expecting that!
Dont need to take front end off at all,just a bit of the inner arch on drivers side for timingbelt,need to take headlight motor off aswell,no room,you've seen pic of mine ben so you know im not lying
Dude calm down (y) no one says your lying, I have read your posts on my-sei and it sounds like an amazing car, but you always seem to add im not lying all the time into posts :confused: Maybe somepeople find it hard to believe but doesnt mean your lying just prove them all wrong at Stanford!
Yeah. 12th June, Stanford Hall in Leicestershire.
If youre there, I'll probably be drooling over your car most of the day (y)
