WARDY25
Ill be there dont worrymits broom yellow with black abarth wheels,with white sticker at top of back window
J333EVO said:When I look at my car it's not just as easy as bolting the stuf on. From the turbo theres an oil feed coming from the section of the engine where the oil filter screws onto, and then you have the oil by pass going direct to the sump where a small pipe has been welded onto to connect the silcone pipe for the bypass! I'm sure it could be done but I question the wisdom in doing so as it may trun out to be more expensive and not done to as high a standard if Van Aaken don't do it, plus you will get a warrenty from them plus the TuV certificate which make sthe car easier to insure.
PLus I was sure they only charged £500 to fit the kit!
Worth considering.
Aaron.
arc said:you could get a rolling road place to setup the fueling etc if u used an MF2 though couldn't you?
EvilJaxx said::bang: Dont want to crash the party half way through but £2000 fitted seem's abit pricy to me and £1000 also sounds abit harsh as you will have some relability issues I would think?
Why not spend £1000 or £2000 on having your FIRE engine machined here there and everywhere to produce the same power as a Turbo and still staying Naturally Aspirated which of course who wants a turbo when you can have the same power from NA?
I guess that is a matter of opinion but to me a NA engine running 100 BHP and a Turbo running 100 BHP the NA would be faster due to having the 100 BHP all the way through the rev range and not just with the Turbo boost?
I am well aware of the increases in torque by the Turbo but surely the NA would mean you can get away without telling your insurancebut they sure as hell will notice a Turbo if you have any kind of accident.... Also the Pssssst of the Turbo is a nice noise but so is the raw of a 100 BHP+ engine with a tiny little car flying past
hehehe
only post this as cinquecento_sunderland's comments were the catalyst for the debate.cinquecento_sunderland said:hi everyone ive seen this car as i live next to him it clean and looks great, if i had the money id have it and turbo it
interesting comment for someone who says the turbo conversion is a waste of time!!!cinquecento_sunderland said:you need an engine that was specifically designed for a turbo these kits are useless might as well stick a 12v fan on air intake like ones on ebay the psi they kick out is a joke complete money waist
LOLinteresting comment for someone who says the turbo conversion is a waste of time!!!
