I am going to buy a Passive sub woofer - and dont really no much about ICE - How do I install it? I have already have an amp and 6x9s, Can anyone help me out cheers
Diss_50 said:it is a 12" FLI (passive) i've done a bit of research and some are live and some are passive Does this mean I install it differently? I already have an amp. cheers
Diss_50 said:Dunno what the RF Punch means?
I am using an amp from TheLoudest.com -
http://www.theloudest.co.uk/?sectionid=2&page=view_product&product_id=74
this will also power my 6x9's
Diss_50 said:tell you what chaos - you seem to be a pro at the ICE game, could you advise me what I should get? On a budget of £200-300. I can put things on hold at the moment - as I've just done with the loudest crap. Cheers.
Diss_50 said:well the 6x9's where part of the package from the loudest.. so I need an amp, sub and 6x9 or speakers. I'm thinking of putting speakers up front and getting a hold of gt doorcards.. what do you think best? i can push the boat out to a max of £350. thanks again chaos
Theres a few 'good' deals on car audio security.com - which includes a sub and amp. think I would just need 6x9's or speakers upfront. But i'd take your advice on what to buy.
Diss_50 said:What about one of these? :
1. http://www.caraudiodirect.co.uk/bass-pack-p-4277.html
or
2. http://www.caraudiodirect.co.uk/bass-pack-p-4278.html
Or should I just go for the GTO75.4 and 10'' JBL sub
garyaird11 said:Ok,
2 ways you can run a passive amp,the 2nd one is the best way,
1. Wire the sub to the 6x9's ,and you'll get bass from the sub aswell as 6x9's
2.get an amp,run the power cable from the amp to the battery,black ground wire to an unpainted solid surface in the car,like a bolt in the boot ,or seatbelt mount ,connect the blue REM wire to the headunit Rem wire,
Wire the sub and 6x9's to the appropriate channel on the amp,
its really simple,you could work it out just by looking at what wires you have etc,
also disconnect your battery while wiring things like this up,it tends to blow fuses sometimes if done wrong.
Diss_50 said:Ok - No 6x9s! I'll get a GT74.5 Amp and a GT 4 sub - are these all active? I want to just plug and play. And upfront i'll get a decent set of components.
